rear brake caliber question
If only one part number is shown, then that caliper fits both variants of the 2006 1300. The abs module is separate from the caliper so generally speaking, most bikes' calipers simply apply pressure to the rotor while a pump or abs module varies the pressure in the brake lines to make the caliper grab and release the rotor.
Thanks
As far as I know all ST1300's use the same rear brake caliper. It doesn't matter what year or whether it is ABS or not. If anyone knows otherwise hopefully they will chime in.
If this is correct it opens up a much bigger used market to you.
