jdmccright
Vendor
I wanted to know how to lube/grease the swingarm pivot. There's no zerk fitting I can see. Is it in the common service manual (I don't have it)? Thanks!
Whaat?Those bearing will require zero pounds of grease across the riding life of your bike.
You are welcome.
I'm thinking this info will fall on deaf ears so please post pictures of what your looked like!
They are tapered bearings, next time you have the rear wheel off, unbolt the rear shock. The swing arm should move easily and smoothly. grab and twist, there should be zero play like a steering stem bearing.Whaat?
