Oh ok thank you very much.Yeah, I'm gonna look up those so the Atlas throttle lock won't do that, will.If you give it gas to pass somebody or whatever it'll stay at that throttle , rightThe Go Cruise is the most functional throttle lock available and it is a fraction of the price of others. Friction locks like the Atlas, Throttlemeister and others hold a single throttle position. The Go Cruise sets a throttle position but the rider is able to increase speed above the set position when helpful yet when released the throttle returns to the speed originally set. It eliminates half the adjustments necessary when encountering hills or passing situations. For example after the GC is set and a hill is encountered the rider increases the throttle to hold speed up grade then the throttle is allowed to return to set position after the crest. Same for passing a slower vehicle with the GC set. Roll on gas to pass, release throttle after overtake is completed and the bike will return to the previously set speed.
Thank you very much , that's what i'm going to getI use the Go Cruise and really really like it and second (or third) everything that's been said. I've used NEP and Vista Cruise throttle locks and the Go Cruise has so many things going for it. Simple efficient design. Very easy to install. Very easy to engage/disengage. The accelerate and return to set speed make the Go Cruise transparent in operation. Super big bang for the buck in form and function.
Guess I'm not that familiar with that model.It looks like the Go Cruise requires two hands to set. Does it, or can you set and release it with one?
It takes only the forefinger of the right hand to set. Simply roll off the throttle to completely remove the previous setting. I have ridden at least one hundred thousand miles using the simplest plastic Go Cruise, not all 100,000 with it set but on bikes equipped with it.It looks like the Go Cruise requires two hands to set. Does it, or can you set and release it with one?
It also seems like it could hold the throttle partially open unless you rotate it closed firmly.
I have been using NEPs for decades. Easy to override either direction, and a flip of the thumb to release.
Ty but a few need more throttle uphills or passing cars , you can do that , and it'll go back to its original setting , or you have to reset it againIt takes only the forefinger of the right hand to set. Simply roll off the throttle to completely remove the previous setting. I have ridden at least one hundred thousand miles using the simplest plastic Go Cruise, not all 100,000 with it set but on bikes equipped with it.
The GC will do that without resetting, but will have little engine braking down the other side of the hill.Ty but a few need more throttle uphills or passing cars , you can do that , and it'll go back to its original setting , or you have to reset it again
Engine braking preserved. Your right index finger quickly and efficiently resets it if need be.OH. Looks like it does NOT take 2 hands, at least for this fella on YouTube:
