Ambient Air temperature Sensor, Part #
Shropshire
Hi All, my ambient air temperature sensor is on the blink, showing 13 degrees when its 22 degrees!! I can not seem to find the part or the part # on the main dealer sites and have found a used one on eBay for £60 which i think is a little expensive... Does anyone know the part # or where i can locate a supplier for a new one?
Thanks in advance
Stuart
I've bought a few parts from Al Gully - a rear brake caliper and a (rear) shock. Both shipped well and as-described for a reasonable price. If I needed a replacement ambient air temperature sensor, I'd start with Al.
Hopefully this is useful: https://www.st-owners.com/forums/threads/2005-st1300-parts-bike-has-been-disassembled.189672/
CC: @Al Gully
I made a big lie.
I'd probably buy a used ambient air temperature sensor and I'd reverse engineer what thermistor was being used because.... nerd.
Your profile does not state what year ST1300 you have, and you didn't include that information in your request. The below P/N is for a 2009 ST1300/Pan European.
You will need to verify the P/N for your model year.
This part is found on the fiche for the lower cowl.
I assume that your in Shropshire, England. Below is an example from Fowlers.
Click on the below link- Item # 2 on the below parts fiche.
SENSOR, OPEN AIR TEMPERATURE, Honda P/N 37890-MCS-G01.
Thanks Andrew, with the part # i have been able to now locate one. Cheers
