Hello. 6 month ago some of my 2003 st1300 clutch friction disks shattered into many pieces while ridding. I made post about it here. https://www.st-owners.com/forums/threads/clutch-friction-disk-disintegrated-why.190847/ Now 6 months later it has happened again. I took it apart and the friction disk had the same problem. It completely fused to the steel plate, I assume from heat. One thing I noticed is that the friction disks seem dry, one seems incredibly dry. I have uploaded a picture of that particular disk. It feels dry to the touch and I think it even looks dry in the picture. These are supposed to be constantly bathed in oil right? It seems like the clutch area is not directly connected to the oil drain pain because in the drain pan that section is partitioned away from the main area. Is there something that squirts oil into the clutch area, or some sort of lubrication system I should try and diagnose. Thank you, any info would be super helpful.
This first pic shows the broken friction disk along with a very dry friction disk.
The second pic is just the clutch area, if its at all helpful.
