Had a perplexing and unnerving problem today: my 2002 ST1300 which usually starts in a second, started after what felt like a minute of cranking! Fuel pump primed when ignition switched on, nothing amiss when cranking (battery barely a month old so cranked at full speed all the while). Once started it ran normally - rode it 5 different times today after the initial issue and started and ran as normal after the first incident. No fuel smell/smoke etc when cranking or when idling/lightly revved after it started.
The bike had a full tank of fuel after it was last ridden for 100 miles or so last Saturday, filled from my usual pump which I've never had issues with (regular E10 unleaded). No additives etc.
After the first crank of 10 seconds or so when it didn't start, I opened and closed the tank lid to eliminate the possibility of vapour lock, but that didn't help.
The kill-switch has never given trouble (I avoid using it). Stand switch has never given trouble either and works as expected. Never tested the tilt/tip over sensor (if the ST1300 has one!).
Bike was in neutral, on the side stand. No warning lights etc when cranking or after it started/while riding.
Thoughts?
Thoughts?
