valve stem seals, methods to access and replace?
reaching the 100k miles on the '00 ST, and the (frequent) urban use demands his tribute to the heat of slow moving in dense traffic...
Already last summer/fall I noticed an oh so slight 'oily whiff' upon starting in the sub-level garage, vanished once on the move though...
To me its getting a little more prominent now, like catching up with you when stopping at a red light... 🤔
Nah, still absolutely no smoke upon whacking it, no "sooth" in the end-pipes, but even ze GF started to pick up the scent, mentioning "I think you're a little smelly!" on the bike2bike... ;)
So while I had the carbs out (swapped them with an overhauled set to eliminate this as cause of bad odor) I peeked down the inlets and indeed:
the valve shafts appear shiny, "moist" if you will, no drops, nothing accumulating there on top of the valve heads... yet... but... rubber hardens over the years, heat-cycles, decades, K miles...
(since the '94 with higher miles still doesn't show such, declining material quality/change of vendors on late models might also play along...)
So I did an oil-change and an extended shakedown run on the weekend, which showed significant improvement (read: ze GF cannot detect anything anymore 😏) but I know its there, so how to attack that issue? 🤔
a) the "classic" way; heads off (= requires new head gaskets), clamp-on valve-spring compressor to lower the retainers to get the collets out, etc... ?
b) the crude way; stuff some rope down the plug hole, rotate cylinder to TDC to jam that against the valves, attach a rail to the head, and use a retainer compressing lever there ?
c) try the modern way with a plug-hole air-hose adapter to hold the valves up by air-pressure (AFAIK are motorcycle valve springs heavier then car types to cope with the RPMs... will 10Bar/140psi even be sufficient) ?
yeah, it'll take some efforts, but since such won't "heal" the miraculous way, it needs to be addressed IMO...
Anyone gone that road willing to share tips on tools and insight? 🤔
TIA
OK, did some research...
this kit seems rigid, well made and somewhat adaptable for the job:
and not to forget: the protector for the (precise) bucket bore; you don't want to scratch that up... 🧐
I would like to avoid having to pull the heads...
Performing this 'surgery' minor invasive from the top would require only new valve cover gaskets and grommets... and be done in like 1/4th of the time... 🤔
I might make this decision based on ...which method means I get to buy the most tools 🔧?
Au contraire...
Darn head gaskets come between € 60~95,- a pop (depending on vendor)... :oops:
Then we've to add the paper ones where t/belt casing meets the heads...
Plus the work, efforts and risks(!) by actually removing the heads... :cautious:
Methinks I'll bite the bullet and go for the € 100,- kit plus that plastic protector/cup...
TIA
You don't need a lot of air pressure to hold the valves up. Get whatever cylinder your doing to top dead center. Just incase something should happen the valve can't fall out. Then you need to lock the crankshaft down to prevent the piston from going down from the air pressure. Bucket type valve springs don't give you a clear shot at the keepers.
The strength of the valve spring has no bearing on how much air pressure is required in the cylinder to keep the valve closed. The valve spring isn't pushing the valve open against the air pressure, it is attempting to close the valve.
Unless the collets are baked into the retainers with oil-coal... ;) (faced that on a 70ies 500/4 SOHC, requiring placing a piece of pipe on the retainer and a few sharp blows with a hammer to loosen...)
Shouldn't be the issue on a well maintained ST1100, receiving frequent changes with quality oil... 😎
Bit the bullet, € 370,- on parts including the protection sleeve (+ an OEM oil filter to make the [free shipping!] threshold 😁 ), and € 100,- for mentioned valve spring compression kit...
it further contains solid air adapters for the plug holes that serve as column for the crossbeam...
pliers to pull the old seals, some shrink-tube over the valve stem tips to protect the new seals, and possible modifying/making a 'valve seal guide' on my little lathe shouldn't be a big stunt either
(chances are that using a 1/4" socket to gently tap them down onto the valve guides will do anyway...)
So € 500,- on equipment and spending a good afternoon in the shed... a/c and favorite tunes on, having a nice cuppa in between... :coffee:
How much would a shop charge for the whole ordeal? 🤔
No need to worry about that. 140 P.S.I.G. is more than you will need.
So you DID buy more tools.
I knew I was on the right track! 😄
And a LOT cheaper then the OEM solution...
1 pcs P/N 077570010000, COMPRESSOR,VALVE, € 276.00,-
1 pcs P/N 07959KM30101, COMP.ATT,VALVE, € 100.80,-
2 pcs P/N 12251MT3004, GASKET,CYLN HEAD (NAS), € 121.20,-
2 pcs P/N 14525MY3000, GASKET,CAM REDUC (NAS), € 21.60,-
so minus the € 100.00,- for above kit makes this about € 419.60,- I've actually saved there... not to mention the hours required for removing and re-installing the heads... 🤔
