Coolant hoses replacement
Den Haag
ST1100 '96
Good morning! What do people buy when they replace the cooling hoses? Already over 100€ for 4 hoses, which feels a bit ridiculous to me since they dont have many crazy bends... Should I just buy some length and 90° pieces and make it fit that way?
Also, does someone know what diameter gas line the ST1100 uses?
Thanks very much!
My first set of these fitted perfectly, serving well in my '00 ST
the next set I ordered for my '94 ST came with one hose missing >5mm in length, impossible to install...
eBay is like a box of chocolate... you'll never know what you get... ;)
I will however order there again the next time the '94 is in for overhaul...
for the overflow and bypass line I ordered some in proper dimensions here (also in black of course! ;)) :
also flawless in both bikes, might require new/different constant pressure clamps due the increased wall-thickness/outer diameter...
For safety reasons I'd go with OEM fuel lines...
[/URL]
[/URL]
Thank you again very much for the help! Good to hear these hoses are working well on the bike, I've read the silicone hoses are not as good with organic coolants used in for example the ST1100, as for example EPDM hoses. I will soon order a set (like end of next month) and who knows, I might be able to go for a ride before fall hits :o. Other parts are on their way (alternator o-ring, coolant elbow o-rings etc), so still plenty to do ;)
Dunno... :shrug2:
so I googled the issue:
Coolant Type
Silicone Hose Compatibility
Ethylene Glycol (EG)
Excellent
Propylene Glycol (PG)
Excellent
Organic Acid Tech (OAT)
Excellent
Hybrid OAT (HOAT)
Excellent
as for the mechanical shaft seal on the ST1100 w/pump its important to use silicate free, permanent coolant (OAT [organic acid technology]) and replace every 4 years to avoid acid buildup...
I have silicone hoses in my 300ZX that have been there 14 years with OAT coolant and zero issues- they are basically forever hoses. The OEM rubber hoses are a bit more expensive but I did buy them years ago for my hose changes on both bikes because I didn’t want to struggle with the bends in the hoses.
Dunno... :shrug2:
Coolant Type
Excellent
Excellent
Excellent
Hybrid OAT (HOAT)
Excellent
Well that definitely didnt happen here (as fas as I can tell), with every hose I pull off more (acid?) crystals fall out :LOL:! Ohwell, I reckon for the first start ill fill the system with demineralized water and flush all the crap out, then fill it with the appropriate coolant after.
Thanks @Erdoc48 and @ST1100Y, thats given me some confidence :)
Thanks very much!
I refurbished my 1991 about six years back and replaced ALL the tubes/hoses. I took the old hoses to a local auto part store and they let me match them up...inside diameter and bend. A lot of the new hoses had to be well trimmed to match the lengths of the old ones. vacuum, water, fuel straight tube ID's were easy....just make sure you don't confuse fuel with air hoses. Even found near-matches for the little 90 degree elbows under the fuel tank.
... fill the system with demineralized water and flush all the crap out, then fill it with the appropriate coolant after...
DI-water and dedicated coolant circuit cleaner (Liqui Moly 1804) is always a good plan on an older engine...
But as said, I'd go all the way, including the O-ring set on the chromed "water pipe" down between the cylinders...
Almost forgot to mention this
As you remove hoses, note the condition of the fitting where the hose was attached. I simply can't leave a quick job uncomplicated so I bead blasted the radiator fitting....the one with the overflow hose and fill cap attached. What looked like good mating surfaces were exposed as having deep corrosion pits which had been filled with a pinkish-silver tinted aluminum corrosion. So I ended up replacing that one and the little fittings under the air cleaner in the area between the cylinders.
My bike looked nearly new when I bought it. The PO had apparently cared for it over the years it spent in his garage.
But.....'rust never sleeps'.
