Gurgling / Bubbling fuel- 2003 ST1300 abs
sTaylor
Chicago
2003 ST1300
Greetings All-
After a moderately spirited ride - but not as long as others, I returned home. After I placed the bike onto the center stand, and the fan cycled off, I heard a steady gurgling sound. Opened the gas cap and saw bubbling fuel rolling up from the right side of the tank. This lasted 3-5 minutes. Never had an issue prior that I had noticed.
I researched the threads for any answers but to no avail. Is this an evap canister issue? Or a clogged fuel vent line? Any insights would be most welcome.
Yeah, it does that. Quite normal - get a torch (UK, so that is perfectly safe - its a bit like flashlight, but better) and you will see the fuel bubbling like a cauldron presumably as air and fuel in the tank cools and looses volume. Go in late at night without a flashlight (that's a bit like a torch but it doesn't matter 'cos you've been brave enought o go in without), and you will sometimes hear the ghost in the tank. To reproduce the effect, breath out and then slowly breathe in and let the air make a noise at the top of your throat. Eerie.
Greetings All-
My bike does it. No issues.
Thank you, fellas. Very much appreciated.
Cheers
“Fire burn, and cauldron bubbles.”
Greetings All-
A sealed gas cap increases pressure in the gas tank, a good thing. pressure reduce boiling point. The gas tank gets heated by the engine.
Gasoline does not have a single fixed boiling point because it is a complex mixture of hundreds of different hydrocarbons. Instead, it boils over a temperature range, starting at about 35 °C to 50 °C (95 °F to 122 °F) and finishing around 200 °C to 220 °C (392 °F to 428 °F)
