ST1100 Powerlet accessory outlet harness new with instructions 30 + 10 for shipping and Pal fee. USA only. This is a Honda 1100 Powerlet part PKT-010 ST1100 no longer available. Message if you need it.
This is an accessory plug made by Powerlet. It mounts on the left side fairing between the ABS/TCS switches and the access panel to the carburetor drain screw- see the below photo.Where does it mount?
Powerlet made good quality accessories. I think that they closed down quite a while ago so these are no longer available, so get it while you can!
There is nothing to prevent a person from installing this plug anywhere on their motorcycle that they wish. The only limitation is if it will fit in the desired location. One of the things that Powerlet marketed this plug for was plugging in a heated vest. Most heated vests had wiring that exited on the left-hand side of the vest making this a logical location. As a result their instructions state to install it in the left side panel as illustrated in the photo that I posted earlier. This is a convenient place to plug in a heated vest but Powerlet also knew that their design will fit in to the space available behind the fairing panel in this location.I thought there was a specific location since it was for an ST1100.
