Hi, I own a 2005 Honda ST1300. I should mention that the bike had been sitting idle for a long time. A brake issue has come up: the center piston in the rear caliper isn't extending—I thought it was completely seized. I removed and cleaned all the calipers and added fresh fluid, then began the bleeding procedure step-by-step: front upper left (OK), front upper right (OK), PVC (OK), rear center (no fluid), front right center (OK), front left center (OK), rear outer (OK). Everything I’ve found points to the SMC; can anyone confirm this, or suggest another way to check it?
