Hondaline Topbox Hinge Repair
It may have been lost in the 'great deluge' but someone posted a neat repair to the outside hinge of a Hondaline Top Box with pictures.
The boxes have a solid plastic strip with a fold in the middle along the back side.
I'm trying to find out what they used as it looked really nice.
Was that you @Alberto ?
Thanks!
That sounds like plastic piano hinge. Is the plastic strip straight and not curved?
Yes it is straight, I just remember whoever did it made it look really good.
Plenty of choices out there for those types of hinges just trying to figure out what exactly the poster used. ;)
Maybe not what your looking for but; my temporary fix has held up well. Partial hinge tear ,when slammed my elbow into it while open. Gorilla Tape . easy fix
That's what I was thinking of - thanks!
I would think the adhesive hinges might work for a while but heat usually softens adhesives. What happens when it sits it the sun most of the day, long trip and then you open the box, will it hold?
Well, there will be some 'additional' fasteners involved as needed ... ;)
That could well be. The heat and sun are not a big problem for very long here in Norway. I think used a few layers of tape. It's held surprisingly well and it dosent stand out as a repair . I had forgot all about it till I saw this thread .
I finally got a 'round tuit' and did my top box hinge repair.
Here's what it looks like -
I used 3 inch PolyHinge from US Plastics (which I had to trim down to fix in the space)
https://www.usplastic.com/catalog/item.aspx?itemid=124631&catid=597
and M6-1.0X16mm cap bolts (with acorn nuts and flat washers) from Amazon to match the OEM look.
https://www.amazon.com/dp/B09G6JNJNT?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
It works as it should and appears that it will hold up nicely over time.
I thought about gluing it but decided bolting it would be a lot more secure.
This was the lid off of BlueBelle that was totalled.
The original bottom was ripped off the carrier bracket and destroyed.
I happened to have a 'donor' bottom from an old short box (they are the same) that I was able to use.
