Hi there! Planning to rebuild the forks on my ST1100 (ABS I version, 41 mm) next year. I’ve started filling the shopping basket with parts and remembered that I should replace the springs as well.
At first I was going to stick with OEM springs, but then I came across progressive springs and thought they might be a better option?
After reading a few threads on this forum, though, I found that aftermarket/progressive springs can require some additional setup- different oil level, different spacers, etc.
So, is it actually worth going with progressive springs on 30y.o motorcycle, or would you recommend just buying new OEM springs and keeping everything close to the factory setup?
