🥶 The Paulcb coldest ride of Winter 2026-2027
-1C/30F this morning. Had to watch for ice (both frozen puddles and frozen streaks made by car tires,) and took it easy on the bridges.
Even though it doesn't count for the game, according to ridercalc.com the "feels like" temp was -13C/8F for me. The formula is based on the 2001 model the National Weather Service & Environment Canada currently use and not the retired Siple-Passel model.
I had the heated grips on 5 and the seat on 1, jacket with liner in, still rocking the Summer gloves and my neck band on to cover that bare skin on the back of the neck between the jacket and the helmet.
It is 34*F outside now. But there are some things I have to do before I can get out. I am planning to put my Kemimoto bar muffs on the handlebars today as it is finally cool enough for those. I also have the batteries for my heated gloves being charged. I typically don't use either of those items until the temp drops to at least below 45*F. I might ride up to my son's house tomorrow but the temps will be closer to 40*F. I need to be there to get my grandkids off the bus.
And... just a wee bit chillier today, than yesterday.
Gosh, it is certainly an advantage to having heated gear that works!
Keep an eye on those controller batteries, gents!
(I bought extras, so if you need AAA's let me know.) 😄
I'm trying something different this year. My Gerbing jacket is working fine. My left glove is barely warm. I've swapped out gloves with the same result.
So I bought some heated glove liners on Amazon and will use those with some outer gloves. It looks like it'll work well.
Phone was in a standard RAM mount with no vibration isolation on it. The extension arm and ball is DIY mounted on my handlebar. The DCT doesn't have a clutch to bolt things nicely on, nor is the handlebar round.
I was also at slightly elevated highway speeds. :police2: just keeping up with traffic officer.
Not ideal for photos, but I did take one when stopped at the lights. It's not fuzzy. Just for you buddy.
Seems funny the controller doesn't use the 12v from the bike and just step it down.
And it's not gone unnoticed.
I occasionally have a problem, seeing things clearly...
The power for the heat DOES come from the 12v connection to the bike battery.
But the controller itself is wireless, and allows heat adjustment to the jacket and gloves separately, via the matching receiver in the jacket pocket.
If the controller fails, I believe the garments may heat to some medium temperature. Separate adjustments for the jacket and for the gloves, on the one controller / Heat Troller, it's called.
It's all explained on the Warm and Safe website.
Can't say I understand all the magic, I just know I really appreciate it when it works. And it does work, when I keep good batteries in the controller. 😄
Ahh that makes it all clearer. I though the controlled was wired, not wireless.
No heated gear for me currently, although I did once-upon-a-time-a-long-time-ago have a heated vest that plugged in. It's controller was built in to the vest so no batteries were required.
Yeah, I was in a hurry, and didn't mention... the pigtail coming off the battery actually plugs into the jacket to provide heat. Then the gloves plug into a lead coming from each jacket sleeve.
The gloves and jacket use standard barrel / coax single plug connectors.
The wireless box - which uses 2 AAA batteries - only allows the heat to gloves or jacket to be adjusted.
Any colder, and I'll be on 12v DC life support.
Back in 2017, I broke a wire in the harness on my left sleeve. Temp was 24? Cold anyway. My Gerbing gloves breathe, probably to keep the hands from sweating. In this case, with no heat in the glove, it was painfull. Extremely painfull. I always carry a backup set of non-heated winter gloves now just- in-case.
I had that very same thing happen on my Gerbing gloves only it was the right glove that stopped heating. I was using the coiled cord accessory rather than the straight cord that came with the gloves. That was on a ride on my ST1100 at -5*F. Yeah, it was VERY painfully cold on that one hand. I could only ride maybe 4-5 miles... to the next exit on the Interstate... and then pulled off to put my hand on the cylinder head to regain some feeling and then continue for the next 4-5 miles. I was 35 miles out at the time. My non-heated winter gloves were just not up to the task at that temp. I went back to the straight cable and all worked fine for the next 8 years when I sold the heated gloves due to then having bar muffs and heated grips.
Dunno if I dare go any lower. But at least I can say I did it.
It all depends on where you live and what the conditions are. If there's moisture in the air, then you can get slick spots on the road. If it gets cold enough, the moisture is gone and it is like summer. I have ridden down to 16F in the past. But that was on roads I commuted on day after day so I knew where the moisture accumulated and could avoid those spots when it got close to freezing. Also, the other vehicles will clear out the moisture over time.
But always use your head. :)
