🥶 The Paulcb coldest ride of Winter 2026-2027
It all depends on where you live and what the conditions are. If there's moisture in the air, then you can get slick spots on the road. If it gets cold enough, the moisture is gone and it is like summer. I have ridden down to 16F in the past. But that was on roads I commuted on day after day so I knew where the moisture accumulated and could avoid those spots when it got close to freezing. Also, the other vehicles will clear out the moisture over time.
But always use your head. :)
Roads were dry. I meant just my current eqpt and attire. LH fingers felt it most. Not painful but def cold, even with heated grips. At least I know I can do it, and lighter traffic would help.
  • Like
Reactions: Obo
I like the look on people's faces in cars when it's below freezing and you pull up next to them. They look over with this "are you nuts?" look that cracks me up. My coldest is -9F but when geared properly it isn't much different than when riding at 40 degrees as long as the roads are clean.
Believe me, here in the DMV they have just as much disdain and as little sympathy as if I were in a cage. I think their only incredulity towards me is that I sit in traffic with them instead of lane split or filter along the shoulder, both of which are illegal here but bikers do it anyways. Which means they'd just rather I GTF out of their way than stare at my frozen arse.
I did around -16C/3F back during COVID lock downs. While working from home, I went out on my lunch, when it was sunny and there were dry pavement "grooves" in the snow packed roads. Did my required distance, but just at minimal safe speeds. The back roads were empty for the most part. The slow cadence helped with both safety and wind temps, not to mention my sanity. No heated gear and only had heated grips on the bike. The rest was just lots of appropriate winter outdoor clothes to cover bare skin and bundle up. They were in no way MC safety rated.
