kennyp
I just put new rubber on my bike and after installing the front wheel it seems the right side pad is dragging quite a bit. The wheel turns 'relatively' smoothly but I can hear quite a bit of drag on the pad. The manual says you should be able to get a .7mm feeler gauge between the pads and the disc. I'm not able to do that on any of the front pads. I can't understand why you would have that much gap anyway. There is nothing I can think of mechanically that would pull the pads back from the disc that far when the brakes are released.
Has anyone else run into this after installing their wheel?
Also, I can't get the axle bolt to sit flush with the fork, like the manual says should happen. I hit it with a block of wood and still it protrudes about a sixteenth (the pinch bolts were loosened when I did this).
