airman
Has anyone ever had or heard of anyone that had engine damage form NOT doing this procedure? I would bet not.
Dumb question but what would be damaged if they were out of spec?
And if a valve were to break like that it would likely get dumped into the cylinder and that would cause all kinds of bad things to happen.
Checked at 16k, 32k, and 48k. Didn't need adjustment 70k now, think I'll check at 100k just for peace of mind.
Did my 01 ST1100 myself, wasn't too hard to check clearances and mine were in tolerance. When I bought the bike (used) I asked the local dealer and was told it wasn't necessary to check. However, I had just finished a valve job on a Suzuki GS-450 twin cylinder due to a burned/split exhaust valve due to tight clearances (only had 75,000 miles). It cost me almost $500 by the time it was done and I did everything except the actual valve job. That was a twin cylinder and relatively easy to take apart, an ST would cost a lot more!
Checking the clearances and writing them down for reference is cheap insurance, in my book. I don't know if I would have tried to re-shim them myself if mine had been out of adjustment or taken it to the dealer to hve it done, but if you don't check them, what you don't know CAN hurt you!
Although not an ST, somebody asked if anybody has ever had valve damage, so the answer is yes."I had just finished a valve job on a Suzuki GS-450 twin cylinder due to a burned/split exhaust valve due to tight clearances (only had 75,000 miles)."
I have a 2000 CR-V that I had the valve cover off last Saturday to replace the timing belt. At 190,000 miles the camshafts looked like new. I swear - no visible wear, no scuffing, no discoloration. They don't call it the Honda Motor Company for nothing. However, it doesn't have shim-under-bucket valve actuation and it doesn't rev to 8 or 9,000 rpm either. Car engines generally lead a less busy and frantic life compared to motorcycle engines. Still, the CR-V has no suggested valve check schedule at all. The manual says check the valves only if "noisy". Many cars have hydraulic valve lifters and have no adjustment at all. The Honda 750 Shadows have hydraulic lifters. I had one and never had to adjust the valves.OK - If I had a Suzuki GS 450 twin with 75K (80's era 30 YEAR OLD design) on it I'd think about checking them!
Actually I'd be pretty religious about checking any OLD bike or CAR. Some modern cars aren't even checked until 100K.
What are valves?
A valve is a device that regulates the flow of a fluid (gases, liquids, fluidized solids, or slurries) by opening, closing, or partially obstructing various passageways.
It was supposed to be a joke. .
