On the 2nd day of my ride to CT/RI I have just passed 2 pickups, a duelly with a trailer and a semi so I'm going East at a *spirited* pace when suddenly the bike begins to slow.
A quick check shows a falling tach and all the appropriate gauge readings (i.e. plenty of gas).
I twist the throttle; but, continue to slow; so, in comes the clutch and I coast to the top of the rise where I pull over and stop as the bike dies.
I get off and look at the bike... and then around me... not good...
I start thinking (not always a *smart* idea! )...
It's cold and rainy... carb icing?
The bike has 82000 miles...
1) Rick's fuel filter?
2) The vacuum fuel shutoff?
If it is carb icing the bike will start working a bit after the ice melts...
I don't have a spare fuel filter (but, I might change the one that is installed!).
If it is the shutoff I will need to strip the bike so... I start stripping.
I get everything off and I check for carb icing by trying to start the bike. No go... it does sputter but, not enough to make me think it was iced.
So I reroute around the vacuum shutoff, hit the starter, it turns for a bit and roars to life. YES!!!!
Thanks Big Tom for your descripton of your failure when you trailered the bike and then fixed it at home!
Mark
Mark
