dteel
I just hope they are as good at putting motors together as they apparently are at getting them apart.
Something doesn't sound right here....
<D>
From my limited knowledge it sounded like the starter motor was turning, but not the engine. Well I think the engine was turning, you just didn't hear the normal sounds before it starts - that why I said it sounded like the engine wasn't turning.
I just got back from my trip to Las Vegas and back. The 5000 mile trip went without a hitch. The first time I tried to start the bike the day after I returned and nothing happened. The starter was turning but the engine wasn't turning over (my first thought was the starter solinoid wasn't engaging the flywheel). Anyway couldn't get it started so I took in.
The dealer performed a leak down test and said that it had a 100% failure. They took off the valve covers and couldn't see any issues there. The next step as to remove the heads to look at the underside of the valves.
That's where we are as of now - I'm about to contact them and see what they've come up with.
Looking for you smart guys to help give me idea what wrong.
By the way am I glad I got the extended warranty now!!!!
Put it in gear and push it, that will tell you if you have compression.
Ask your dealer if they heard of a bore scope, easy and don't have to pull the heads.
If the starter spins and the engine doesn't, there is a one way clutch, check that.
so on and so forth.
Try a push start to see if it's the starter or battery.
