Thanks
She runs like new.
I have done quit a bit of preventive maintenance to try and avoid a break down while on the road:
Winter project,
New Alternator with harness
All new throttle body hoses with T's
All new water hoses
new water pump - (seal failed.)
new plug wires and caps
New U-joint
New clutch plates
New OPS ( oil pressure sensor)
New water temp sensor
Front / Rear wheel bearings
Valve adjust
SMC replaced - rear wheel brake drag
New OEM wind screen- original -delaminated and scratches
Just to name a few.....
Normal Maintenance:
Tires
Oil changes - Air filters
brake and clutch fluid on regular basis
New Battery
New fuel pump -- clean lower tank
Flange bearings
Steering bearing
Thermostat
