Bike For Sale 1993 ST1100
Price
1000.00
Current Mileage
100524
Current Location
Gages Lake, IL
ABS
No - NOT ABS Equipped
Gages Lakes, IL
1993 Honda ST1100
93' - ST 1100
100,524 miles
Thsi bike is at the stage that it is either a great parts bike or if you are willing to do some work a great bike for the next 100,00 miles. Bike currently has a collant leak from a cracked water pump housing. The bike will also need the clutch replaced. It works fine if you ride nicely, but if you dump the clutch it is starting to slip. The timing belt will also need to be replaced. Bike is currently running but all the plastic is off (yes i have it all) and the radiator is removed so to will need to be trailered off. Yes you can start it an dhear it run. That's the bad, now the good.
Over the last 5 years all the hoses have been replaced
1/ 1/2 ago all 3 brake calipers have been completly rebuilt, replaced the front disks
same time replaced the clutch slave cylinder
has a 40 amp alternator
less than 2000 miles on a new set of dunlop Roadsmart 3's
Bike has been very well taken care of with all routine maintenece
2 seats - Corbin and Stock
2- windscreens 1-Givi, 1- 24" tall clear
Givi mono key with top box
Added 6 position fuse box under the seat
Body parts are in good shape except the rear cowl is in need of replacement.
Have many sapre parts
Too much to remeber
Asking $1000 - Pic is from 2 weeks ago.
