The vacuum bleeders are good at pulling the fluid into the system - but they are useless for the final bleed. The problem is, that even if you wrap PTFE tape around the threads of the bleed nipple, when you suck air through the nipple with a vaccuum pump, it is easier for it to pull air past the thread and back up the hole in the centre than it is to pull the fluid through the system - even with PTFE tape on. So you get a constant stream of tiny bubbles.
