How difficult to replace the Rear Shock Absorber
Danny J
Danny J
Thanks....Good to knowThe real pita is unthreading the preload adjuster hose from the frame and rear fender. And of course, when I was putting mine back, I made a mistake and ended up taking the rebuilt shock out again and reinstalling it.
The second time goes a lot faster.
Thanks .....good to knowIt's a little complicated at first as the way the bolt is inserted into he lower end requires loosening up the side plate. Once you reverse the orientation, it becomes a little easier. Here's some discussion:
Article [13] - ST1300 - Rear Shock Removal | ST1300 Articles
I replaced my shock this past weekend. Here are some observations. It was more involved than my ST1100 was, but not that bad. - removed rear wheel (was replacing rear tire) - didn't remove right step holder, just loosened bolts to clear removing the lower shock bolt. Reversed the bolt when...www.st-owners.com
