Rider RSS 2026 Honda CB1000F Preview
2026 Miles
002794
The new 2026 Honda CB1000F transforms the CB1000 Hornet SP platform into a retro-inspired machine that harkens back to superbike racing of the early 1980s.
2026 Honda CB1000F in Wolf Silver Metallic
This bike is specifically inspired by the inline-Four CB750F and CB900F models, which Freddie Spencer raced in the AMA Superbike series beginning in 1980, paving the way for Honda’s mid-80s racing efforts highlighted by riders like Fred Merkel, Wayne Rainey, and Bubba Shobert. This new interpretation features flowing lines that connect the fuel tank through the side covers to the rear, chrome downpipes, an exposed engine, and graphics inspired by Spencer’s AMA Superbike. It also features a 4-2-1 exhaust with a three-chamber megaphone-style muffler.
The CB1000F uses the engine that debuted in the 2017 CBR1000RR. The 1,000cc inline-Four has been tweaked for use in the CB1000F, including revised camshafts for exhaust and intake valve timing and tuned intake specifications. These changes result in an engine that prioritizes performance at lower rpm, improving throttle response below 6,000 rpm. The gearbox is also revised, with 1st and 2nd gears getting lower ratios for increased low-speed response and 3rd through 6th gears getting higher ratios for low-rev cruising.
The fuel tank holds 4.5 gallons.
The bike also comes with five ride modes that affect engine power, engine brake, and Honda Selectable Torque Control, with each parameter having three levels. Ride modes include Standard, Sport, and Rain, as well as two User modes that allow the rider to set parameters and save the settings for future use. Cornering ABS is also included.
The bike’s one-piece, steel diamond-style twin-spar frame is borrowed directly from the CB1000 Hornet SP, and the subframe is specific to the CB1000F. The rear fender and seat bottom panels are made from pre-consumer recycled polypropylene material. The bike offers a relaxed and upright riding position with a 31.3-inch seat height, and the curb weight is listed as 472 lb.
A period-correct three-chamber megaphone-style muffler.
A 41mm inverted Showa SFF-BP fork offers preload and rebound/compression damping adjustment, and the Showa shock with Pro-Link can be adjusted for preload and rebound damping. Stopping power comes from dual radial 4-piston Nissin calipers pinching 310mm discs up front and a 1-piston Nissin caliper paired with a 240mm rear disc.
In spite the CB1000F’s retro styling, it benefits from several modern amenities. The Honda Smart Key allows riders to turn the bike on without removing the key from their pocket. Lighting is all LED, including the classic circular headlight with low beam on top and high beam at the bottom. A 5-inch TFT display allows riders to choose among Bar, Circle, and Simple display patterns and connects to smartphones via the Honda RoadSync app to access navigation, phone calls, and music.
The dash features a 5-inch TFT screen with smartphone connectivity. It’s controlled via a toggle switch on the left side of the handlebar.
The 2026 Honda CB1000F is available now in Wolf Silver Metallic for $10,599. Visit the Honda website for more information.
Check out more new bikes in Rider’s 2026 Motorcycle Buyers Guide
The post 2026 Honda CB1000F Preview appeared first on Rider Magazine.
Not my favorite style of the older Hondas but I still like it a lot. Disappointed with the gauges though. I still love analog for tach and speedo. And the other retro Honda with the twin meters with the needles going pin to pin on startup... Sick-trick!
Here's a video overview of the new CB1000F:
I can't find the retro model that resembles the ol' 750-4. I'm sure someone here has/had one.
