Outlaws
Outlawarrior
Planning front brake & clutch hose upgrade to steel lines & figured it would be a good time to replace brake pads as well.
After reading several threads on the subject here I plan to stick with OEM pads.
Searched several parts sites & come up with this list,
Front pads
45105-ML7-922 PAD A, FR. (Honda Motorcycle Code 3138930) (SEE KIT P/N--END OF BLOCK)
$14.52 2 $29.04
45106-ML7-922 PAD B, FR. (Honda Motorcycle Code 3138948) (SEE KIT P/N--END OF BLOCK)
$18.94 2 $37.88
Rear pads
43105-MT3-007 PAD A (Honda Motorcycle Code 3485430) (NOT AVAILABLE)
$23.70 1 $23.70
43106-MT3-007 PAD B (Honda Motorcycle Code 3485448) (NOT AVAILABLE)
$14.52 1 $14.52
Washers-brake & clutch hoses
90545-300-000 WASHER, OIL BOLT (Honda Motorcycle Code 0189902)
$1.79 9 $16.11
Washer-clutch hose @ master cylinder
45535-MT3-010 WASHER, OIL BOLT (Honda Motorcycle Code 3485786) Use up to Frame SN MM10127
$4.28 1 $4.28
My question is,
You can't get pads for these in sets for a reasonable amount???
And what's with the $$$ difference from A & B for the same caliper???
Am I missing something here or is there a better source for these???
Thanks in advance, Mike
Front pads
$14.52 2 $29.04
$18.94 2 $37.88
Rear pads
$23.70 1 $23.70
$14.52 1 $14.52
$1.79 9 $16.11
$4.28 1 $4.28
My question is,
