Mr. BR
Just a local commuter...
Last night I started in on the 40amp upgrade for my ’95 ST11 with 75k miles. I had pulled the lower fairings off earlier in the week so I could quickly dump the oil and filter after my commute. So last night it went up on the lift and 3 hours later I had everything removed: gas tank, rear wheel, swing-arm, old alternator. Straight forward work and everything came off as expected. I had a 17mm hex wrench for the swing-arm bolts but not the special tool for the “castle” style lock nut ring. For the ring, I gave it a wack with a hammer and large brass drift and it loosened; both sides are marked so I can get them back to where they were before. Call it “shade-tree wrenching” but it works. The stator cover bolts were a little hard to access but I had extensions and a swivel joint to get my hex drive on them. And yes, they were a bit stiff and “squeaked” during removal. I was a little worried that that the hex-bolt heads would strip out but they didn’t. A little gentle prying and the stator come off and then the gear drive. However, it took me about 10 min. of jockeying the gear drive around to actually get it between the frame rails. My bike is a CA model so it has the wire loop for two hoses going to the Vapor Recovery Canister. I bent the loop down and that helped (I believe it needs to be removed anyway). The new Alt unit is from a ’97 ST11 with less than 20K miles on it according to the salvage yard I purchased it from ($500 plus tax and shipping for Alt, drive gear, harness, fuse block). The unit is clean and the brushes measured 10mm so I’ll leave them be. My Lewis pin was made from a std door hinge pin. I just happen to have one laying around and found it to have a 6mm dia. (cut, drill, deburr, polish and voila! One Lewis-Pin clone ready to go). We’ll see how it actually works with my clothes-hanger rip cord!
Regards,
Mr. BR
Regards,
Mr. BR
