oude geit Joined Jan 14, 2018 Messages 113 Location alabama Yesterday at 7:35 PM #21 If it locks up on you, loosen the top center bleeder valve it will release the brakes. Front brakes where fine.
jfheath John Heath Site Supporter Joined Mar 18, 2006 Messages 569 Location Ilkley, W Yorks, UK Bike Spyder RT Ltd 2026 Miles 000050 56 minutes ago #22 oude geit said: If it locks up on you, loosen the top center bleeder valve it will release the brakes. Front brakes where fine. Click to expand... If the problem is with the SMC failing to return properly, that will not help. That pressure build up can released with the rear-most bleed valve. But you are right in that the front brake lever and front outer pistons will still work.
