I watched a you tube video on how to check for ABS fault codes on an ST1100. I did the procedure and get fault code 5 - frt wheel speed sensor system. Im not sure if this is an artifact from a previous issue that has been repaired or if it is currently an issue. Does anyone know how to clear this fault code? If the condition that set the code still exists then the code should come back. If the condition is gone then the ABS should work as normal.
In the short time I’ve had this bike the ABS light has not come on at all while riding. Lights seem to operate normally, come on when started and goes off as soon as you start moving. I have, once, tried a hard stop to see if I could activate the ABS and they did not activate. I thought I experienced a little brake fade but I’m still getting accustomed to this bike. Otherwise I’ve not experienced anything that has caused me concern. This bike is much heavier and more top heavy than my last bike, a CTX700. It braked well and I could easily activate the ABS at will on that bike. I figured I would wait until I got new tires on the ST, which are now on but I haven’t had the opportunity to try the ABS again.
Does anyone have any input on this? TIA, Bill.
