ABS light does not stop flashing
Dean
Lifes good but ST better
Hertfordshire
ST1100 1999 ABS
I think I have sorted a code 4 problem out on the abs system through a very kind fella called Christopher who sent me through a manual on disc. I have now another problem being that the abs light will not stop flashing when riding even when you push the abs reset. Once you stop moving the light stays on then starts flashing again when you set off. Has anybody come across this problem and of course was there a solution kind regards Dean
winchester UK
st1300
Have you removed the fuse and rode the bike ..you will still have brakes ....then replace the fuse ...fault might go away
OR remove the Plus side of the battery go for a cuppa the replace the lead ...fault might go away that way ....
just a thought
Firstpeke
NT1100D
UK
Honda NT1100
7764
The 1100 ABS sometimes responds badly to a low battery voltage or connections that need cleaning and protecting.
I have had this on my previous bike, rode for a couple of hundred miles with the light flashing, stopped, filled up, restarted, no light. Battery must have been getting a bit low.
Never had it again after that.
