Does anyone have experience with Admore's LED46-T-TS lighting kit for the Givi V46 topcase? Installation and operation? Can it be purchased in Canada?
Bert
05 ST1300
Bert
05 ST1300
Wiring the Admore kits to the 1300 is a snap. All you need to do is remove the rear fender and you've got easy access to the brake and turn signal lines. Snake the wire from the kit down there, attach a few Posi-Taps and you're done.
The kit comes with quick connectors which work well to tap into the wires under the seat, The five wire harness from Admore connected to the following colored wires on my '07:
Harness color Blue to tail light wire Blue/Brown
Harness color Red to brake light wire Green/Yellow
Harness color Green to Right turn signal wire Light Blue
Harness color Yellow to Left turn signal wire Orange
Harness color to Ground
Good luck and Enjoy!
Dan
... when you have it wired up can you still easily remove the topbox or is there a connection to seperate? thanks
