Going through to change out the old brake fluid on my 2005 ST1300 non-abs. Following the manual directions was going fine right up to the part where I went to bleed the PCV and got no fluid through the PCV bleeder screw despite backing it well off.
I’m using a manual vacuum/pressure bleeder tool that is holding vacuum and worked well with all bleeder valves in sequence both before and after the PVC step.
I drained both front and rear master cylinders just short of running dry and kept filling with fresh DOT4 fluid. I did let the fluid get low in the rear master cylinder just once and allowed a bit of air in and then flushed multiple containers worth of new fluid to try and make sure all air was bled out.
Looking to the collective mind for suggestions.
