I don't remember the gauge of those green/yellow wires, but if they are of sufficient gauge, this would work if you can't find the origin of the two brake light wires.
Personally I'd leave the stock brake lights alone, and install the flasher circuit on the top box light only. The stock brake lights are so dim they are useless anyway.
I'm unsure what you mean by 'single master wire'.I just need to know where that single master wire is.
Thank you for thinking of other. I so detest see those that I won't put others through it.. even if it does help my safety.This way I don't continue to annoy someone stuck behind me at a light with a constant flashing light.
Perhaps a sketch showing how to connect these four Green/Yellow wires to the Kisan brake flasher module would help.
If all you want is to have the Kisan unit flash additional brake lamps (Givi trunk), then the electrical installation is less involved, no need to interrupt the existing brake lamp circuit as was necessary when the Kisan was going to flash all brake lamps.Again as suggested, I think I'll hook the flasher up to my Givi tail box lights.
