Hi
Need some advice my brakes have been sticking for a while now garage used kits to rebuild rear master cylinder and secondary master cylinder last year and all was well for a while.
First of all it was my rear brake now its both rear and right front brake. the right disc is badly marked with the brake pads scorching the disc.
Last time the bike was in they bled the brakes and it has been fine for a while then my rear started sticking again so lubed up brake pedal and again fine, now front right brake is sticking again badly and rear is also.
At a loss as what is causing this any ideas? Is it worth replacing rear master cylinder the complete assembly or is it something else.
They removed calliper last time and cleaned and full brake bleed.
Really need some advice as this has been going on for a while and desperate for a solution.
Thanks
Thanks
