It's certainly bitterly cold in my garage which is where I've been most of the weekend!Good morning @Johnny24 !
I bet it is bitterly cold over there in Scarborough.
Just to be certain - are you talking about the inlet port - the one that is circled in red on this picture of a new SMC ??
That cover is secured by 2 bolts that can be seen, and is sealed with a rubber O ring.
Beneath that is a very important mechanism which has a very find white gauze. It is probably the gauze that you can see. I'll post some pictures - but in the mean time, do not go probing it. It is a filter cartridge and a one way valve, and is safety critical !!!
Yes -t he tough white plastic plugs have to be removed before fitting. They are, as you rightly surmised, in place to keep the dust out.
I'll be back with the pics.
Here you go. First with the black cover removed, showing the O ring and the gauze filter.
And here showing both sides of the filter.
View attachment 251605View attachment 251606
And here showing the filter taken apart.
This removed from a dead SMC. Its not advisable to remove it, as it is very delicate and not easy to do without causing damage. And since you cannot buy them separately.....
The purpose ?
Its purpose is two fold. The inlet port allows fluid into the SMC chamber to provide a constant supply to the rear outer brake pistons. When the SMC is released, the device shuts off the inlet port so that fluid from the SMC cannot be pumped back up the brake lines. The gauze is there (there are two circular gauze filters - the white circular one on the left - the one you can see once the white plug has been removed, and the one with the blue cap which also supports a spring). Both stop any debris from entering the SMC piston bore and also interfering with that one way valve seal.
All brake system master cylinders have a compensation port. This is a very very tiny hole which allows the relief of pressure from the brake lines as the pistons in the caliper return, and also to allow for expansion or contraction of the fluid as the temperature increases or decreases. If fluid cannot escape through that tiny hole, the brakes can remain locked on. (Nothing to be alarmed about by that statement, that is how the brakes work).
However, with a normal brake lever, if the brakes did not release properly, you would be aware of it instantly. In the case of the SMC, you do not have the 'feel' at the brake lever or the brake pedal. So if brake fluid is not changed at least every two years (I do mine every year), then problems can begin to form and the rider would not necessarily be aware of the problem developing . And the SMC has 2 compensation ports - one in the side of the SMC bore, one just behind it in that plastic housing - by-passing the one way valve.
Is it a concern ? No. I've ridden 170,000 miles on bikes with SMCs, without issues. It's knowing how to service - and why - that I think makes the difference.
Scarborough to Ilkley is a pretty good ride - we often do it - if you ever want to come and pick my brains. (Pretty lean pickings on some days though !).
Thank you for the quick, full and helpful reply. Yes, I was indeed talking about the inlet valve on the SMC. After I'd posted my query, I looked more closely at the old SMC and was able to see the white gauze at the bottom of the inlet, and could also see that as I worked the plunger on the cylinder some remnants of the old brake fluid came up through the gauze which a) reassured me that it was not impermeable b) indicated it was supposed to be there and c) stopped me from poking around at the new one. Anyway, the new one is all fitted now, slider pins cleaned up and re-greased and the next job is to put in some fresh brake fluid and hope it all works.
I understood from one of your other posts (Going on an Air Hunt) that there was a compensation port at the bottom of the SMC inlet but I hadn't appreciated that there was a membrane/gauze as you have described.
The bike is having various jobs done at the moment as well as sorting out the brakes. Once all the plastic comes off it's sometimes difficult to stop! It all needs to be shipshape as I'm off to the continent in two weeks (coronavirus allowing); North Sea Ferries to Zeebrugge, down to Perpignan, along the N260 on the southern side of the Pyrenees to the Picos de Europa, then back from Santander to Portsmouth and home.
Send me an email next time you come over to Scarborough if you feel like meeting up for a coffee.
