Hi everyone. I just got myself an ST1300 with 99k miles.
Been looking through the forum for a while and I observed that there are some pictures of leaks in other threads that I could relate my symptoms to.
I started noticing this leakage when I started smelling oil being burnt. Upon checking, I see the following:
There are traces of oil on the right exhaust header as well:
Smoke is observed when I run the engine from the exhaust that are covered with the oil AND THAT IS WHAT produces the smell.
I did clean the drips to see if there is any leakage but to my surprise, there are no drips after wiping them off.
So I did ride it around for awhile and when I checked again, the leak is observed.
I'm unsure which component is failing but from what I read, and with the possibility that the leak reaches the exhaust header, I assume that it is coming from above and that would potentially be the output shaft seal (I could see some oil on the rubber ("clover").
Would be glad to hear some input from the seniors!
Thanks
Thanks
