Has anyone ever looked into having rear-wheel hub splines repaired, such as by filling with weld and re-machining the teeth?
I've not seen anyone posting a thread discussing this, so I would assume the answer is 'no'. Of course this could be done, but unless the ST's owner was a machinist with access to appropriate tools, it would likely cost more than purchasing a used wheel and final drive. Rebuilding the final drive involves shimming the gears - not a big deal but again, it requires tools, parts, and some experience.Has anyone ever looked into having rear-wheel hub splines repaired, such as by filling with weld and re-machining the teeth?
the main "dish" is forged steel; a glowing hot lump of metal dropped into a mold, a huge 'hammer' slams from above with several tons of pressure to shape and harden the thing...Has anyone ever looked into having rear-wheel hub splines repaired, such as by filling with weld and re-machining the teeth?
That's if you can find the parts.I don't thing that anything you'd arc or spray weld on that area will have the same metallurgic rigidity...
And setting up the machine + the hourly rates for the shop will exceed the price of a new set of OEM splines by far...
I have a great deal of respect for these guys - they work magic (well iron and steel) with old (aka primitive) tools, however, I suspect the warranty might not be up to Honda's standards. Seriously, were you marooned in Pakistan it might be an option, but for @Larry Fine in Richmond, VA ebay would be a better option.There are guys in Pakistan. India. Probably elsewhere....can machine anything..forge anything. Cast....half hour or less.
Not really that complicated provided the correct machinery is available. It is a pretty straight forward machining job for any competent and properly equipped machinist who has the correct dimensions. Nonetheless doing so would be cost prohibitive for anyone paying standard rates to have it done.You’d have to be one heck of a machinist to pull that off.
P/N 42630MT8305 is shared among the GL1500 and ST1100 range and seems readily available...... try to cross-reference it with other Honda bikes too to broaden availability (GW? PC800?).
