Before I replace the fork seals, is it advisable to get new springs? I'm not the sort to spend money to spend it. It is a 93, so you are talking 20 year old springs. Any experience appreciated.
.... so you are talking 20 year old springs....
I did Progressive springs, new fluid, when you change out the seals do all the other little stuff too, slide bush & guide, o-rings, bolts, washers, etc. Tapered head bearings and I also did a MCL fork brace too! You will like it!!
finding the part numbers for the other bits you mention isn't easy
New springs, fluid and steering head bearing transformed my '94. Had about 65k on it when we (Team Colorado) did the swap.
I want to refurbish my forks as well, though the head bearings seem fine and the fork seals aren't leaking, so I am wondering if I would just get away with changing the fork springs,10 wt fork oil and new bushings?
finding the part numbers for the other bits you mention isn't easy.also someone mentioned a fork brace, I read somewhere that the absII bikes already have a fork brace because of the way they are designed? maybe I'm totally wrong on that though, thanks
The head bearings may seem fine but until you switch over the roller tapered bearing, I guess you don't know what you are missing.
I would definitely replace those brass bushings too! I'd also maintain a replacement interval of 36T~48Tkm on that fork oil from now on (shorten it if you often ride under very dusty and/or humid conditions...) Despite the dust seal on top and the double fork seals beneath, the fork oil receives a lot of contaminations due the large surface area of the fork tubes the seals have to work on, which will start chemical deterioration on the oil; adding up to this are factors like heat and shear forces during the suspension work, plus abrasion particles from mentioned bushings and fork bottoms. Take a flashlight and look down into just drained a fork bottom and you might see lots of black stuff plus some water droplets having accumulated there. Fork oil is not meant to remain in use for like >100Tkm; doing so will lead to mechanical wear/damage to fork bottoms, tubes and other internal parts. After draining the fork oil (standard models do have drain bolts on the low outside of the fork bottoms; forks of ABS-II/CBS models require removal to turn them upside down for purging oil/liquids) I also given them a good rinse with some fast evaporating brake cleaner (also give the dampers a few strokes while this stuff is still in there), which washes out a lot of black goo, even while the drained oil still looks rather good, not tinted/discolored and transparent. Attach an air hose to blow them free and leave open for a while to vent out, before fill new fork oil. YMMV...I am waiting the arrival of new seals that are coming to Ozz from the UK...
my $0.02 - Change out all the little cheap bits. I'd rather spend a few dollars too much than to have to pull the forks apart later and do it again.
