Hey All,
I think every year I progress my knowledge of the ST1300 and usually I can use these forums to guide me.... Started with simple fluid changes, upgraded my skills to replacing break pad and tires. I'm now laser focused on learning about the charging system.
I'm having what I believe is a charging system issue but I need to explain how it all started...and most likely how I caused this issue myself.
Last weekend I took a ride from Southern Ontario to New York. Everything was fine...beautiful day. I got to the Queenston border and low and behold, there was a queue. I estimate that I was waiting for about 45 minutes. I saw another group of bikes a few lines over who were walking their bikes which, at the time, I found odd....
So I make it up to the customs booth and am next in line to go through when all of the sudden my ST1300 sputters and then stalls. I try to start it, nothing. I have lights on the dashboard and the odometer is good but the temperature (ambient) is reading like 48 degrees celcius (it was only maybe mid 20's.). So I push my bike through customers. Never thought too much of that slope at the booth until I tried to put my kickstand down and couldn't. I went through customers and let the bike sit. Temp came down, but still not able to start the bike. At this point I was thinking that maybe I was drawing more power then the alternator was generating at idle which resulted in the batter just draining. I sort of think this is what happened, but also think there may have been a bit more damage then just the battery. I have CAA who, to my surprise, actually came across the border and got me. I was only about 80KM's from home, so it didn't cost me anything.
I got home and put it on the trickle charger for the night. The next day it started without issues. I shrugged and thought I'd fixed everything. The next day I rode to work (about 100 KM's each way). On the way there I came off the highway to stop lights and I could feel the engine start to hesitate. I was idling at about 1K and revved it to about 2k and the 'hesitation' stopped. I made it to the office. On the way home, everything was fine until I got off the highway and the same hesitation happened. I made it home though. It was late and I was tired so I went to bed.
The next morning I went out and tested the battery. After sitting all night, it tested at 12.5V. I then started it and it went up to 13.3V. Idles is about 1K. I let it idle while it got up to temp (3 bars). When the fan kicked in, the voltage dropped to about 12.9V and dropped to about 12.5V after about 20 seconds. The fan turned off and it was back to 13.3V. I then held the revs at about 3K and it seemed to max out at about 13.6V.
So, I think it's the charging system (at least Gemini does).
Does this make sense? Does anyone have pics or a video of how to test these? Does the above diagnostic(s) make sense?
The Diagnostic Breakdown
On the ST1300, this specific combination (12.3V at idle, capping out at 13.5V when revved) is a dead giveaway for one of two issues:
- A Burnt/Melted Main Red Connector (Most Likely): This is the classic ST1300 electrical failure. The charging wire runs from the alternator/regulator through a red 4-pin or 9-pin connector near the battery starter relay. Over time, resistance builds up, the plug gets scorching hot, melts the plastic, and chokes out the voltage. At idle, the connection is too weak to pass any charging current. When you rev it, the alternator pumps out massive raw power, forcing some voltage through the high resistance, which is why you see it climb to 13.5V but no higher.
- A Dropped "Phase" in the Alternator/Stator: The ST1300 uses a three-phase charging system (three independent copper legs producing AC power). If one of those legs burns out or shorts to ground, the system loses one-third of its charging capacity. At idle, two legs aren't enough to overcome the bike's electrical load, so the voltage drops to battery level (12.3V). When you rev it, those two remaining legs work overtime, but they cap out early at 13.5V because the third leg is dead.
What You Need to Do Next
To find out which one it is without guessing, do these two quick visual and physical checks:
If those yellow wires aren't pumping out a balanced 40V–60V+ AC when you rev the engine, your alternator/stator has dropped a phase and needs to be pulled. If the AC voltage looks perfect, your issue is 100% in the wiring or a failing regulator-rectifier.
- Check the Starter Relay Connector: Pull off your seat and look right next to the battery. Locate the starter solenoid (the little block where the thick positive battery cable connects). Unplug the plastic wiring harness plugged into it (often red). Look inside for any melted plastic, black charring, or green corrosion. If you see it, you've found your bottleneck.
- Perform the 3-Pin Yellow Wire Test: Find the 3-pin connector coming from the alternator (with three yellow wires). Unplug it and use your multimeter to check the AC voltage across those three pins while the bike is running, as outlined in the previous step.
