BudC
'91 ST STOC# 422
Especially if it's a 91. (BTW, mine has the 40 alternator in it, which turns out to be irrelevant)
Tried to start the bike ( still not riding, but I needed to move it) and... dead.
Symptoms. Turn on key. Nothing. Actually, something: the clock blanks out. Check battery voltage. Looks good- 12.7 with key off and key on. Check at fuses. Voltage at bottom (clock) fuse: 12.7V key off, 1.6 V with key on.
Ok. High resistance somewhere in the circuit before the clock fuse. Maybe the ignition switch. Remove the air cleaner to get at it, pull the connector to the ignition switch. Made up a little bypass (wire with two male blade connectors on each end) and plugged it into the connector, simulating the ignition switch. Same symptom. Not the ignition switch (whew!).
Poke around in wiring, pulled the starter relay connector, fuse looks ok, but I'll pull it to make sure that it hasn't developed high resistance. Hmmm. It doesn't want to come out. Ok, get a big pair of needle nose and pull. 2/3rds of a fuse comes out. Part of blade remains in.
Picture attached. The blade to receptacle on one side of the fuse corroded and started melting both the fuse and the plastic around the female connector. Have a new starter relay assembly on order from David Silver. That should fix it.
After this, I looked around to see if this was a common problem. Evidently not, but I did find a similar thread here: https://www.st-owners.com/forums/threads/steeds-gone-dark.56146/#post-628124
So, after 37 years (I'm pretty sure I've never replaced that fuse - probably never even looked at it), Father Time decided to mess with me.
Check that fuse - pull the starter relay connector to get at it - pull it out, clean it (a little steel wool) and spray contact cleaner in the connector. Smear some dielectric grease on the blades and shove it back in. Save yourself $60.05.
