I know, I know... Probably gonna have to tear into the carbs. But out of curiousity if any one has experienced this too, I have a spark plug that for the past 1000 miles has remained sooty compared to the brown of the rest of the plugs. I suspect a stuck float or a bad float needle, but dont want to overlook an easy fix. Oddly this is the same spark plug that had a fried spring inside the boot, and nigh infinite ohms.
After riding around 210 miles the fuel light came on. Going 75 most of the way, this equated to about 35 mpg, which sucks. After filling up and running the numbers, as soon as I turned in near my neighborhood, I felt a cutting out of sorts, One could say bogging too. Revving the motor you could clearly hear a lack of a cylinder/ bank. It held Idle fine however, just any throttle or load and it was gutless. Disassembly lead to #3 spark plug sooty..
THATS NOT ALL. Cycling the key (and consequently fuel pump) 6 or so times lead to a gurgling coming from cylinder number 3's carbs, lasting about 20 seconds with 6 pulses. . . .
