Tom did you mount the Hankook yet?
Jay
Yes, Jay.... As of yesterday I am officially a DS'er.
The weather here warmed up to mid 40's so my buddy and I did the change over from a 020f to the V12.
Didn't get to even test it yet as we worked, we sort of got further into the St Paddies spirit and I didn't want to take it out... .And today IT"S f'ing snowing again!
A couple of notes...
1) when cold ( even tho in sun for an hour or so ) that tire is a bear to mount ! I thought the 020f were hard. We had to kneel on the tire ( actually climb on ) to keep it in the hollow of rim so the other side would go on.
in all , went sort of like a GW tire change... a bear! Gettin off will another story
2) The tire DIDN'T pop on the rim bead when inflated like most mc tires... then again there was prob so much lube it prob slid on quietly.
3)***
check your Flange bearings*** changed out a set at 15k miles, now at 40k or so one side ( outer towards wheel / inner one was perfect ) felt scratchy. Since I had a set we swapped the two out with new.
4) tire was balanced as is. I have my rim pre balanced and then after tire on it was within 1/8 of an oz so I left it. I marked the rim and tire with nail polish to see if any rotation on rim ( tho I don't think its a prob )
5) used the plastic bag trick over the swingarm parts and it went right in with a hair over 1/8" clearance , not even close to rubbing.
And to finish off
ITS HUGE !!!
