Continuity in your output cable is a bad thing. Yes, you could have done real damage or not. Did you straighten out the conductor?
I'll try this tonight and see what happens, thanks.Something else you might try regarding the extra cable is not store it in a straight continuous loop. My understanding is that the continuous loop can cause issues as it creates a field. Instead us a figure 8 pattern with it. You want to loop back over itself which is supposed to disrupt the ability to create a field and cause issues.
I didn't see your post 19 before my post 20. I would still check the mounting bolt etc. I have read that a short in the antenna cable or mount will damage the radio. It mainly causes damage when trying to transmit. I don't think it happens immediately though at least not with the J&M depends on how long it has been that way.
Any local hams around that can help out ?
Bring it over here and I'll fix it !
Here is another way that I learned from here on the forum and worked on my bike. Use the standard 9 ft cable from the radio to the antenna. Make sure you have the orientation of the banjo bolt at antenna end correct and nylon spacers are installed correctly, this can be reversed if not careful and short out your antenna. Then add a 9 ft number 12 stranded coated wire from the ground post on the antenna and loop around under the seat. Do not ground the other end. Then check your swr. Before this I could not get a good swr, now I am good on all channels.
Here is a little more topic. https://www.st-owners.com/forums/showthread.php?85216-J-and-m-2003-and-grounding-antenna
If the coax was still attached on one end to the antenna when you measured the short, it may still be ok. Some antennas provide a DC ground. (I don't know about yours, but I'm guessing the center conductor isn't grounded - in which case something is shorted.)
If the coax was completely disconnected on both ends and you measured a short, it's definitely bad. Either someone did a bad job of mounting the connectors, or the coax was damaged badly (and this amount of damage should be pretty obvious).
Coax was disconnected and looked like it had been smashed pretty flat in more than one place. It looks like it had a braided metal coax cable, but with a outer clear coated plastic.
I put the new longer coax on it with the same SWR results, and it was not grounded from the connection to the center pin.
Think I have it close enough for it to work well. I put an extra 9' 12 gauge wire onto the bracket mount and ran it along the frame. I did not ground it, just wire tied it to secure it. Got SWR of 1.5 at ch. 20. & closer to 1.1 on ch. 1 then got 1.9 on ch. 40. Going to let it go at that for now. Thanks for all the info. Gary.
