Absolutely....the two water fittings under the carbs, all the hoses...water, fuel, vent....and clamps. Remove and clean the thermostat housing, I suspect the fittings are deeply corroded under the hose es, especially the little one that runs back to the overflow bottle.You're in that deep, now is the time to replace every piece of rubber you can get a replacement for. Then ..... you will have no concerns.
I agree. And don’t forget the small ‘bypass’ hose from the thermostat housing to the Water Pipe.Absolutely....the two water fittings under the carbs, all the hoses...water, fuel, vent....and clamps. Remove and clean the thermostat housing, I suspect the fittings are deeply corroded under the hose es, especially the little one that runs back to the overflow bottle.
IIRC, yes, Honda lists bulk hose for that, and I believe it can also be used for the reservoir hose if you don’t want to buy that one with its own part number (save the sleeve).So far I have the L,and R Thermostat as well as B Water Hose ordered. Are you talking about the Bulk Hose part no 13 on Partzilla
95005-55003-20M
No opinion on that. As to the oil cooler hoses on the early models, I’d think any bulk coolant hose should work fine. Inspect them… I suspect they’re quite functional yet. Foreign car parts places should have metric hoses (coolant, fuel, vacuum).also, thoughts on Evans coolant to avoid pressurizing the system?
better yet, save the time and just buy 4 new ones, they're not that expensive.Inspect the carb insulators very carefully for cracks. They are old and likely brittle and pulling the carbs likely strained them
I took my nla hoses to local auto parts shops to match up the bends. Clerks at both allowed me to rummage through their stock. Nothing was exact but I was able to cut the correct lengths from the new hoses and installed them with no kinking or chafing. I did NOT identify which car they were made for....that would have made for an easy suggestion, and future reference for myself.Just a quick question...I did all the hoses under the carbs as well as the bypass hose and the main radiator hoses in early 2018. I didn’t change the oil filter hoses to the water pump though as they were unavailable. When I remove the plastics in the next year or 2 to tackle just those (on the 94), any suggestion for what to use? No leaks at all and it only has 43K miles on it...just don’t want an unexpected failure in the future.
I have run Evans in my ST since 2009 and also in all my vehicles. No corrosion, no oxides in the system. All internals look brand new still. No water means no corrosion and no boil over. Some will argue but I have the same Evans coolant in my Dodge pickup since 2006. Never needs changing.Just a quick question...I did all the hoses under the carbs as well as the bypass hose and the main radiator hoses in early 2018. I didn’t change the oil filter hoses to the water pump though as they were unavailable. When I remove the plastics in the next year or 2 to tackle just those (on the 94), any suggestion for what to use? No leaks at all and it only has 43K miles on it...just don’t want an unexpected failure in the future.
Yep I already have them coming. My hope is to only have to pull the carbs once so not afraid to spend money for parts or getting them rebuilt right the first time.better yet, save the time and just buy 4 new ones, they're not that expensive.
So I'm pulling the thermostat housing to clean up corrosion as well as replace the thermostat and hoses. Underneath the neck filler there is a small tube and a wire. Can I just pull the wire off or do I have to wrench it off? I'm guessing it goes to a sensor.Absolutely....the two water fittings under the carbs, all the hoses...water, fuel, vent....and clamps. Remove and clean the thermostat housing, I suspect the fittings are deeply corroded under the hose es, especially the little one that runs back to the overflow bottle.
I've more experience with the 1300, and am not sure which hose you want to replace. Most guys here would order the OEM hose, unless it is no longer available. That's when making one up from say, AutoZone's or NAPA's stock comes into play. Smaller hoses (e.g. 1/4" I.D.) are usually replaced with stock hose off a reel. Just make sure, if you go non OEM, that the hose is appropriate to the use. Someone reported a submersible fuel pump came with a hose that deteriorated and fell apart when put in the fuel tank.They were pretty bad and basically were cracking getting them off. My hope (right?) Is pull the carbs once getting them rebuilt by a professional, replace anything in there so I don't have to worry about it again for 15 years. Will any radiator hose from the top of the radiator to the bottom of neck filler work or do I need to order that also?
