I had the exact same issue. Replaced worn lever and bushing still wouldn't start in gear. Ended up being the tip of the switch itself was worn down and was not being pushed in far enough. Replace with a new switch. Work perfectly now.
As disproved by SCIENCE.I before E except after C. antisieze
Hilarious - what dictionary are you using?I before E except after C. antisieze
While your makeshift fix may work for a while, what it will cause is to keep wearing on the lever eyelet, until you start getting up and down slop in the lever, which will damage the perch that is the entire master cylinder housing, which is a few hundred dollars to replace.Even after replacing my clutch handle bushing around 80k mi the clutch switch not always "clicking" when pulled in. Figured it was wear on the switch plunger, so I glued an aluminum shim to the lever pad where it contacts the switch plunger. No probs since!
I grok.I'm sure you can grasp what I'm saying and take hold of my intentions to arrest your attention as we talk about this clutch issue.
There is no rubber bushing on the rod, what you are looking at is the torn off end of the old rubber boot.Hey Guys I need some Help. I ordered parts: Clutch lever, Bushing, and Push Rod (22884-MB0-006). The push rod came without the rubber bushing in the middle, and the OEM one looks brittle, so I think it will crack/split if I try to remove it from the old to put on the new Push Rod. Any suggestions?
Thanks
I grok.
Apologies, but...I had to seize the moment https://www.merriam-webster.com/dictionary/seize
Done now, your welcome...(anyone, c'mon).
