Industry-leading provider of aftermarket parts and accessories for Harley-Davidson motorcycles Drag Specialties has released five new parts this month. Enhance your Harley-Davidson’s comfort and performance with these products, and check out the Drag Specialties website to find the full catalog and to locate a dealer near you. No matter which Harley you ride, Drag Specialties has something to make it even better.
Quickly and efficiently replace the OE upper clutch cable with a quick connect upper braided cable from Drag Specialties. The cable easily and quickly connects to the OE lower clutch cable section to significantly reduce installation time; no need to drain the transmission fluid. Cables also come pre-lubricated for smooth, consistent long-lasting action. The design meets or exceeds the OE specifications, and the OE cable cover and housing can be re-used. Available with black/black cable housing and fittings in stock cable lengths for 24-26 FLHX and 23-26 FLHXSE models. Replaces OEM# 37200574A. For 24-26 FLTRX and 23-25 FLTRXSE models replacing OEM# 37200592. Suggested retail is $95.35-117.61
The Freedom Touring seat features a 5.75-inch tall driver support with unique styling and is covered in high-quality automotive-grade vinyl. Seating area is contoured for maximum comfort and is made narrow up front for better leg clearance. This seat also works with our EZ Glide frame-mounted receiver mechanism to accept EZ Glide backrests. It will also work with H-D and OEM frame-mounted backrest mechanisms and backrest pads. Available in double diamond stitch with black or silver thread for 15-25 FLRT and 23-25 FLTRT models. All mounting hardware is included. Made in the U.S.A. with a suggested retail price starting at $570.89.
Save your belt from unwanted elements with a Rear Belt Guard from Drag Specialties. Made of high-quality stamped-steel with simple bolt-on installation. Available for 09-26 FLHT/FLHX/FLHR/FLTR models (covers OEM guard); replacing OEM# 60408-09. Suggested retail price is $91.97.
Shift into gear with these heel/toe shifter kits from Drag Specialties and Gilles Tooling. These adjustable shifter levers are constructed of CNC-milled 6082 T6 aluminum and allow shorter motion for shifting. The spline axle features aggressive teeth flanks for added bite. Front and rear pegs are double eccentric with the front having 360-degree adjustment and the rear adjustable in angle. The shift arm is adjustable in three ratios. Available in either black or black/gold finishes for 99-25 FLHT/FLHX/FLTRX/FLTRU/FLTRK, 09-25 H-D FL Trike and 00-17 FLST models. The suggested retail price is $356.93-400.22.
Brake with confidence. The Drag Specialties Rear Brake Caliper Kit provides the same reliable braking time after time. Rear caliper accepts OEM bolts and comes with brake pads and bleeder screw. Replaces OEM# 41300097. Available in chrome for 15-17 Softail models and have a suggested retail price of $410.50.
The post Drag Specialties Releases New Aftermarket Products for Harley-Davidson Motorcycles appeared first on Rider Magazine.
Quick Connect Braided Upper Clutch Cables
- 2024-2026 FLHX
- 2023-2026 FLHXSE
- 2024-2026 FLTRX
- 2023-2025 FLTRXSE
Freedom Touring Seat with Backrest Option
- 2015-2025 FLRT
- 2023-2025 FLTRT
Lower Rear Belt Guard
- 2009-2026 FLHT/FLHX/FLHR/FLTR
Adjustable Heel/Toe Shifter Kits
- 1999-2025 FLHT/FLHX/FLTRX/FLTRU/FLTRK
- 2009-2025 FL Trike
- 2000-2017 FLST
- 2015-2017 Softails
