I just changed my first ST1300 Slave cyl.
I first used a syringe to remove all the nasty fluid in the master and used paper towels to clean the residue out of it.
Then I got slave off the rear cover.(First I removed-Shifter-Hose holder-Oil Filter-Speed sensor.)
Then loosened the Banjo bolt and washers.
Cleaned the gasket off the cover.
After adding brake fluid to the new slave.
I reversed the procedure.(loosening the Bleeder tube eyelet bolt-Allowed some metal tube movement getting the banjo bolt through the Master hose & metal bleeder tube.) a dab of grease on the washers helped keep them in place while getting the banjo bolt through the sandwich,into the slave.
Make sure to start the threads into the slave (with just your fingers) "Without" using a ratchet wrench
To finish installing the bolt, Because it's not hard go strip the aluminum threads in the slave,if the bolt doesn't thread in easily (if you do strip the threds?-You'll buy another Slave and start over.)
Bleeding the fluid was straight forward.
Add fresh fluid in the master, and open the bleeder. Then let gravity take over. (with one of the clear hoses attached on the bleeder nipple.)
I made a catch container W/two hoses going in just like the little cup most vacuum pumps come with.(it holds more fluid.)
I can flush out most of the brake caliper & slave bleeder valves without needing the Pump attached to the other hose in my catch container.
Pump the lever a few times, While keeping lever pressure to the grip.
I open the bleeder valve, and watch the fluid going into the catch container. I close the valve, and repeat the process.
I usually pressure bleed four full master bowls of fluid (to make sure I cleaned out the Master And Bleeder tube lines with fresh fluid.
