If you have the ability on your VFR to adjust the fork rebound dampening with a screw on the top, do me a favor and give it a few turns to the stiffer setting direction. (make sure you measure how much you changed it by so you can put it back) My experience shows you'll get that same harshness without changing the spring preload at all.
sorry Dwalby, what the adjustment on top of the vfr's fork does is adjust the preload.it has ring marks around it so its easy to keep track of,and keep her even on both forks.
when I had her on the standard recommended setting,3 rings from the top IIRC,she was great on a good road surface, nice firm feel in the corners.
but when riding on back roads with poorer surfaces she felt very harsh,not smooth enough over the bumps, so I backed of the preload so that 4 rings from the top were showing,and it smoothed her out,far nicer ride on the back roads.
I don't want to end up making the pans suspension feel this harsh,but she is softly sprung,and me being around 240lbs geared up doesn't help the situation.
maybe increasing the preload on each fork leg,by say 1/2 inch would stiffen her up enough.
PS. yes I have read post 36,and I see what you're saying, might not work for me unless I hit the gym hard for a few months LOL, and having a broken toe at the minute that's not going to be happening for a while anyway.
