Good morning everyone,
After clean my front brakes, I hear at low speed my brakes pads in contact with the disk.
I lift my front wheel and the friction is light but I can hear when I ride...
I have tried several times to set the fork arms but it is not perfect.. (the wheel turns correctly without brakes)
I read in french maintenance manual 1100ST the specific setting of the front wheel (left brake is already installed)
0-Engage the wheel
1- install axle and don't tighten (just bolt in contact)
2- respect 0.7mm between brake support on left hanside
3- tighten the bolt clamp (below the fork)
4- install right front brake and tighten
5- tighten axle bolt
In item number 2, I don't know where I have to respect that 0.7mm
I have the english maintenance manual but there is no description about it
If someone have one advice? thanks in advance
0-Engage the wheel
