Correct, and I said as much before. I carry a rain suit, but I never ride in the rain intentionally. I'd rather ride on gravel.You obviously haven't ridden in the rain much.
That reminds me of the old Jack Benny radio bit where he's being mugged:but I never ride in the rain intentionally. I'd rather ride on gravel.
I’ve been running nuvis on my ST for 11 years now, I just put sandwich bag over it during downpour. I refuse to pay zumo prices. My screen stays on mph speedometer while in US, so I don’t have to look down. It’s right in my line of sight on my raised dash.Ive used a Nuvi for years.... wondering why upgrading to a zumo ......
Does this mean that my Nuvi 2597, that I was hoping to use for a STOC event this year, will not allow me to put routes in it and then follow it? Does that explain why It re-routes me to the shortest route to the end versus following the drawn out loop I created?Zumo's are waterproof and more robust than Nuvi's. That said, I did what you are doing and ran a Nuvi for a year or two with no problems. The Zumo will allow you to download routes made on Basecamp and call up either the route for turn by turn guidance or as a track which simply shows the route and allows you to go astray. In other words, the Zumo gives an advanced user more options. It will also lighten your wallet significantly and that translates to less weight on the bike and faster acceleration.
I am not sure. But if under preferences, you have the Nuvi finding routes that are "shortest distance" that might be why. I do not know how to disable all of those so it follows your route. We had the same problem on our MABDR run and we discovered if you disabled recalculate feature on Zumos, we were ok. Don't know about Nuvi's.Does this mean that my Nuvi 2597, that I was hoping to use for a STOC event this year, will not allow me to put routes in it and then follow it? Does that explain why It re-routes me to the shortest route to the end versus following the drawn out loop I created?
According to this, the 2597 (2507 series) is compatible with Basecamp. Make sure you put enough waypoints in your Basecamp route so your 2597 will route the way you want.Does this mean that my Nuvi 2597, that I was hoping to use for a STOC event this year, will not allow me to put routes in it and then follow it? Does that explain why It re-routes me to the shortest route to the end versus following the drawn out loop I created?
Mine isn't on either list. 2460LMTAccording to this, the 2597 (2507 series) is compatible with Basecamp.
Does Basecamp recognize it? I did a little searching and it "seems" some are using it with Basecamp, but that was 10 years ago. Being that old, it may not connect to the latest version of BC.Mine isn't on either list. 2460LMT
Sounds like it might be set up perfectly for you...that will ensure you are back to the starting location sooner than me and you won't have to look at my taillightDoes this mean that my Nuvi 2597, that I was hoping to use for a STOC event this year, will not allow me to put routes in it and then follow it? Does that explain why It re-routes me to the shortest route to the end versus following the drawn out loop I created?
I have no issue with creating the route (I think), perhaps the way I'm doing it may be the problem. I do not have waypoints added in which it seems may force the route. I am new to Basecamp and might be going about this the wrong way as I create the route. I'll have to watch some more videos I guess.Some Nuvis do and some don't use custom routing. If 2597 does, than you shouldn't have problems following your route. As said before, set more via (also known as "way" or "shaping") points, not just start and end, so they'll be connected by Nuvi as you wanted the route to be. Your "shortest distance" option only tells Garmin how to lay out your route between the points. Garmin does not loads your route. It loads your points and then decides how to connect them together into a route. For example it there are many different roads between your points, it will calculate with the shortest distance (or any other option), and it may not be what you had in mind when creating the route. However, if there are more via's, then you're forcing Garmin to connecting them as you want since there aren't other roads around. In this case a shortest distance or fastest time is not relevant. I don't know if basecamp and Garmin are in sync (what you see in Basecamp is what you'll see in Garmin) cas to me Basecamp is too tedious and not user friendly. I use 3rd party software (Furkot.com is one) to make custom routings.
I use "fastest time" as an option in case if I want to use highway and not to bother putting the via points on it.
Hope it helps.
Try this...I have no issue with creating the route (I think), perhaps the way I'm doing it may be the problem. I do not have waypoints added in which it seems may force the route. I am new to Basecamp and might be going about this the wrong way as I create the route. I'll have to watch some more videos I guess.
Here's another consideration in using a Nuvi vs the Zumo. Bluetooth.Does this mean that my Nuvi 2597, that I was hoping to use for a STOC event this year, will not allow me to put routes in it and then follow it? Does that explain why It re-routes me to the shortest route to the end versus following the drawn out loop I created?
When they have constant exterior power they go in to sleep mode, essentially just turning the screen off. They consume negligible power in this mode, and this is why they use so little power.When I pressed the power button, the screen immediately would go black. When I pressed the power button again, the screen would come back immediately - like it was in sleep mode - didn't go through the Garmin logo boot up, and only took a few moments to find satellites again, while also remembering the route I selected at departure. Using this method, I was shocked to find the power brick showed a full 4 bars power (4 of 4) on my return home!
Every Zumo that I have owned as well as every one that I have ever used has this feature.It also has a feature I greatly missed on the Zumo - called "look ahead" or something like that.
Once a route is keyed in, you can click on fuel or food or lodging ahead on your route and it will list options off by distance.
Well, I know I may not be the brightest bulb in the box, but I spent a considerable time working with my Zumo to find the same "look ahead" feature offered by the Nuvi and to no positive result. I'm sure you are correct, and it's available - but not without a considerable amount of work to find it...which is not the case in the Nuvi.When they have constant exterior power they go in to sleep mode, essentially just turning the screen off. They consume negligible power in this mode, and this is why they use so little power.
When you do a search, you need to select the option to tell it to search along your current route to have it display only what is coming up.
