Thank you ever so much! I’m very much looking forward to this modification,
A 5mm nutclip can be fitted there for a shortened windshield “truss screw”, to replace the plastic push-pin. BTDT 130K agoI'm curious whether the "Garnish" can handle the extra strain that this mod might cause. I'm thinking I may have to install well nuts at the bottom of the garnish much like we do when the tabs get broken. Just putting it out there.
First mod I did when I got the 2002 ( you pointed me in that direction for my first ST). Thanks John. This indeed is a good tip.A 5mm nutclip can be fitted there for a shortened windshield “truss screw”, to replace the plastic push-pin. BTDT 130K ago
I’ve been making a grid on the screen. Once I get the givi airflow I will measure it and line it up with the base screen. Thanks for the tip. (I’m aiming to cut the screen down to 310mm which is close to what you cut yours down to)Hi Kiltman, the 20 inch surface may not be perfectly symmetrical. I suggest checking straightness where the sliders will go. I found my OEM was very slightly asymmetric (less 1mm) while fitting the mounts. It showed up while tightening the latch bolts. This was surprising for OEM but manageable.
Regards
Garry
That sounds fine. I put the mounts 4cm from the top to the centre to give me the height range of 430-550mm. Screen has 120mm travel. That suits my 196cm height.I’ve been making a grid on the screen. Once I get the givi airflow I will measure it and line it up with the base screen. Thanks for the tip. (I’m aiming to cut the screen down to 310mm which is close to what you cut yours down to)
Robert
I’m vertically challenged compared to you at 188cm. . Having said that, my current clear view screen with the wind deflector is at the 530cm position. So I will basically be doing the same thing with the Givi combo.That suits my 196cm height.
I had a Rifle. It was straight.Hi All,
I would like to compile a list of screen models that are straight for their entire length (no lip). The reason being is they are the best candidates for an airflow conversion. For example: I understand that Eaglescreens H72 is straight but I have not checked in person.
Are there any others. Can anybody help here?
Regards
Garry
Thanks sirbikeI had a Rifle. It was straight.
Rifle
Because it cuts out the back pressure from behind the rider. It was one of the changes Honda made to the STWhy did you cut the cat eyes in the new screen?
